Ir para o conteúdo principal
Repair information for blood pressure monitors (also known as sphygmomanometers).
I used 12v adaptor instead of 6v, now it has stopped working.
Hi,
I used wrong 12v adapter instead of 6v in bp monitor, now it has stopped working. What to do now?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
How can I fix my blood pressure monitor
por
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
You most probably have a damaged voltage regulator and / or other input supply voltage components on the monitor's control board.
You will have to open it up and inspect it for any obvious damage.
Post some close up pictures of any damaged areas on the control board (hopefully it will be obvious but perhaps it won't be) and maybe someone here will be able to help.
Here's how to do it.
Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 6
It’s possible it used battery power during the time it worked and due to not getting a charge through the 6v power supply, it’s now drained. Try getting the right power supply and try again.
Pontuação 2
Adicionar a sua resposta
Ameit Laal será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 2,230
