My controller keeps constantly moving to the right in game.
I Just bought a brand new Xbox one S from Best Buy exactly one week ago and I’ve been using it since, but for the past 2 days I have noticed while playing a FPS Game or Forza, my car would slowly turn to the left. Keep in mind this controller is practically new and hasn’t been dropped yet. If you know the problem or have a solution please let me know.
Esta é uma boa pergunta?
6 comentários
My original controller from a Xbox one PUBG bundle pack started drifting in run mode so I bought this new controller & it’s great! U have to buy the afterglow prismatic wired controller with 10’ cord & download the PDP app for Xbox one & PC to configure it & change the colors. No need to buy an headset adapter or headset. Saved me 120$. The controller is 28$. My regular Koss Porta Pro headphones (no mic) work great after I downloaded the app. —-> https://www.pdp.com/pdp-app —- > Check out this item at Target https://www.target.com/p/afterglow-gamin...
por Melissaaylor
I had the same problem. Turns out, one of the bumper switches (left bumper) was pressed in and stuck. Once I saw that, I pried it back out, now all is ok again.
por gustep12
This will not Void the warranty. Opening the controler WILL. Best thing is get several Q-Tips and alcohol. Soak in AL then push down in the opening of the JS. Do it several times and getting that alcohol in there. Move your JS back and for a lot. Repeat. Keep doing that for about 4-5 Q-Tips . Remembering to move the JS all around right after the AL goes into the JS. Alcohol evaporates quickly, so let air dry for a little bit and that should help. If it doesn't, but it is better, then do it all over again until it fixes it. If it doesn't help at all you will either need a new controller or to open up the control and cleaning and fixing that way. But, opening the control Voids warranties. So if still under warranty, do not open . If you have bought recently and in under warranty, Go replace it, or call Microsoft to replace it.
por kalenkerby
"I had the same problem. Turns out, one of the bumper switches (left bumper) was pressed in and stuck. Once I saw that, I pried it back out, now all is ok again." Sorry for the thread revive, (but this is still a current issue) but so strange how the left bumper affects the left joystick! Thx gustep12
por 10th Leper
how do you connect a wired controller does it turns automatically turns on or not?
por Nathan Puth
Exibir mais 1 comentário
