Ir para o conteúdo principal
wiring from alternator to starter
where does the thicker wire from the alternator connect onto the startermotor?
Esta é uma boa pergunta?
Pontuação 2
1 comentário
kobus, this is not the model that has the starter/alternator combination?
por
Adicionar um comentário
1 resposta
Solução escolhida
Generally the heavy wire from the alternator goes to the battery terminal on the starter motor.
Esta resposta foi útil?
Pontuação 4
1 comentário:
Hi there George, thanks connected it like that and it works.
My problem was i replaced the starter but took a while to re-install it and could not remember how the wires went and connected the wire from the alternator to earth and blew the rectifier in the alternator.
Thanks again for your assistance.
por
Adicionar a sua resposta
kobus será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 11
Duração total: 6,106
