brakes locking up in booster
my brakes keep locking up in the booster i bougt new one install new brakes all four new master cycder bleed all lines it still locking up in the booster new vac on it to to release the brakes i take off the vac hose and it will roll what going on
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Does it have ABS installed? If so you will need to use the correct method to bleed your brakes via your ABS.
por
no abs i notes that the fill tub don't have a wire hook up its has a wire hook up hanging but it don't have ABS braking
por
Adicionar um comentário
