Ir para o conteúdo principal
Support and repair information for Beats Solo3 headphones.
Why isn't my beats wireless solo 3 not charging?
my beats are on 37% so they're still working ok on bluetooth. however, i tried charging them and they won't charge (no lights, nothing). i tried resetting them about twenty times (pressing on the power button and the mute simultaneously for a 10 seconds up to 2 mins). the lights would flash for a few moments, signaling that they are reset, but it still won't charge. i'm afraid my battery runs out within the next couple of days and i won't be able to charge them. please help! i've only had these for about a month now.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
I'm pretty sure the charging port is broken. I have the same issue on my Beats and that's where all the signs seem to point to. I advise not paying Apple to do it (bc it's expensive af) and buying one and doing it yourself. I'll update when I get the chance to replace mine.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Have you tired to fix the charge port yourself? I'm having the same problem. I changed the battery and that wasn't the issue. I connected the cable and it's not indicating that it's charging
por
Adicionar a sua resposta
fidel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 8,150
