Pular para o conteúdo principal
Determining U2 or Tigris failure on an iPhone 6
Hello,
Just looking into an iPhone 6 and the device boots and behaves normally, it draws between 0.08mA and 0.50mA. It changes the battery icon when the cable is plugged in.
Tried 3 computers, 2 different cables and 2 connector ports - same results.
I would typically suspect U2 if it was drawing 0.00mA.
From reading, Tigris is the element that deals with USB communication.
The voltages around this area are ok, theres a 1.8V, VCC_Main, USB5V0. none of the caps around here read anything different when normal.
The USB connector on the board itself is physically clean enough.
Before going ahead with a U2 swap I am wanting to know is it best to swap Tigris first because to me this seems like the most likely culprit.
Thank you :)
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 Solução
Solução escolhida
Although I doubted if the U2 was even the issue because power was getting inside the phone, replacing the Tristar IC did the trick. I usually like to refer to STS Telecom for this fault, they have a good video that I refer to if I need it:
https://www.youtube.com/watch?v=XLFkvPA_...
Problem fixed!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Elliot será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 96
Todo: 2,580
