My PC shut down during a windows update due to power failure, now a w
My PC shut down during a windows update due to power failure, now a windows icon is stuck on the screen for over 4 hours, what should I do?
Esta é uma boa pergunta?
Hi,
If you have Win 10 installed try to get into the WRE (Windows Recovery Environment) menu area.
To do this, turn off the laptop and then start it again. Once it starts allow it to start to boot into Windows and then force stop the laptop by holding the power button until it shuts down.
Do this procedure 3 times, i.e. start > boot > shutdown, start > boot > shutdown. On the 3rd attempt it should boot into the WRE.
Once there select Troubleshoot > Advanced > Start up Repair and follow the prompts.
Do not select Reset your PC as this will erase all your data and reinstall Windows.
If this doesn't work use the same procedure and try to restore your pc using a system restore point or a system image (if you have them that is)
If you haven't got a WRE for whatever reason on your laptop, you can create a Windows 10 Recovery USB from any known working Win 10 computer. You'll need an empty 8GB flashdrive and about 60 minutes of time to do this. In the computer go to Control Panel > Recovery. When you have created the USB drive, plug it into the laptop and then alter the boot options in the laptop (usually press F12 on startup) to boot from the USB first. It will load the WRE and you can try the startup repair as mentioned before.
Esta resposta foi útil?
thank you
I was able to revert my locked computer to an earlier windows version and try to download/reinstall the newer window version
My desktop shuts down during a Windows update from an external hard drive due to power outage and after that, I didn't have access to the external hard drive, the main storage doesn't show on the computer only the system reserved storage. Please what can I do??
Hi @heritageade ,
Just to clarify.
The Windows OS is on a HDD that doesn't show up in BIOS, is this correct?
If it is detected by BIOS and if the reserved storage partition is located on the same HDD then the other partition information may have been corrupted.
Did you try booting with a Win 10 USB recovery disk as described above to check if it can detect the OS at all?
Thank you of the answer
I have solution for this situation
What you do first
In order to fix this problem, you’ll need to use Registry Editor. To do that, follow these steps:
1.When you see The computer restarted unexpectedly error message press
Shift + F10 on your keyboard. This should open Command Prompt.
2.Enter regedit and press Enter to start Registry Editor.
3.Once Registry Editor starts, navigate to the
Follow the step
"HKEY_LOCAL_MACHINE\SYSTEM\Setup\Status\ChildCompletion"
and double click the setup.exe in the right pane.
4.Change the Value Data from 1 to 3 and click OK to save changes.
5. Close Registry Editor and restart your computer.
I think I shouldn't left my laptop even I'm just a minute stirring up my coffee, I am rebooting my laptop with Win 10 (O.S) when suddenly after I get back, my screen was went black. What could be happening onto this? I should’ve have just reboot my laptop to a professional, than doing it on my own. Why should I do? Please help
Open Bios menu and flash a new window . Its easy. But, doing this will loose your all data in the computer.
Hi @daria00520 ,
Did you try the Start Up repair option as described in the Chosen Solution above, you didn't say?
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 45
Duração total: 77,663
5 comentários
[image|1884231]
I can't get passed this it keeps doing it over and over after factory
por Robert Kreischer
Factory reset
Hi @Robert Kreischer,
Try the option described above on how to repair the installation using a USB drive.
You may have to get into BIOS to enable USB legacy support or CSM (don't know your laptop options) so that it will boot from a USB stick.
Once in the WRE menus (loaded from the USB stick) try the repair option as described above.
This time you will be repairing from the USB Windows files and not the files stored in the laptop.
por jayeff
Same problem
por Sakshi dang
My laptop is lenovol340 and it is showing the same thing
por Sakshi dang
