My 88 Sierra SLX
Can I take the transmission out of my 96 Yukon and install it into my 88 Sierra SLX short wide bed
Esta é uma boa pergunta?
Will,
Those XMSNs won’t swap. The ‘88 Sierra uses a THM400 and the Yukon uses a 4L60-E. Although the bolt pattern maybe the same, the wiring harness won’t match up and the XMSN won’t shift properly.
I’d find a reputable shop that can rebuild your THM400 or clear off a spot on your bench to do it yourself. XMSN rebuilds can be tricky, however it would be a great time to add in a shift kit.
Here’s a resource for the reference:
https://www.transtar1.com/transmission-l...
Good luck!
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 109
