Ir para o conteúdo principal
Modelo A1502 / processador 2,4, 2,6 ou 2,8 GHz de dois núcleos / Lançado em outubro de 2013
552 Perguntas Visualizar todos
MacBook won't turn on After replacing Thermal Paste.
Hi there,
My MacBook Pro Retina 13 inch Late 2013 won't turn on after I changed the thermal paste. I cleaned the CPU with Articleaner, the thermal paste is arctic silver 5. While cleaning, a little bit of the thermal grease and cleaner got around the cpu and motherboard. No cables or any additional hardware has been removed or changed, the CPU has been treated carefully while reapplying and cleaning the thermal paste. The black cover/plastic around the cpu dye was peeling off while cleaning carefully however. The MagSafe Connector gives a green light, which is for me personally an indication that their shouldn’t be any shortage or damage, right? I can’t perform any kind of reset, no smc reset or anything else.
I am so far clueless and don’t know what I can do in order to make the device work again, I hope you guys could help me out with this troubleshoot.
Thanks in advance!
Esta é uma boa pergunta?
Pontuação 1
1 comentário
I did plug in everything appropriately but it still doesn’t work....
por
Adicionar um comentário
4 respostas
Solução escolhida
Try unplugging the magsafe adapter and the battery. Now press and hold the power button for 10 seconds. Next reconnect the battery then the mag-safe and see if you get a spontaneous reboot. Observe the progress bar and please report any anomalies.
UPDATE
If this fails I don't have a clue. You might do best to contact Apple and request a "flat rate repair" Total cost in Texas with shipping a tax runs $357 and takes a total for four days. Apple with have a FEDEX shipping box at your door the next morning. They will fix any and all failures for that fee it it has not received liquid damage or impact damage. Call 1-800-MYAPPLE, get to an agent and request it. You will need the serial number and a credit card.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Just tried your solution and unfortunately it still doesn’t turn on, nothing happens and the green light from the Mag-Safe still turns on...
por
That’s really unfortunate... but still thank you both for your help!
por
Hey there! I had a similar problem after repasting mine, however I found it started when I plugged in my charger - turns out the keyboard wasn't plugged in properly, so the power button didn't work!
por
Did you remember to plug the battery back in? I always forget that, also thermal paste is non-conductive.
Pontuação 0
6 comentários:
por
what was the reason you re-applied thermal paste? was it working before?
por
It was working, the cpu was getting really hot and I thought that reapplying the thermal paste after around 4 years would be a good idea....
por
@mayer may be more knowledgeable on this topic than me He'll be here soon.
por
Thanks in advance!
por
Exibir mais 1 comentário
So, did you fix it? I am with the same problem here.
Pontuação 0
I had a similar problem, I had reattached a cable in reverse!
Pontuação 0
1 comentário:
What cable? Currently have this problem
por
Adicionar a sua resposta
Fer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 19
Duração total: 3,107
