Samsung tv won’t turn on. The standby light flashes 5xs
My Samsung tv won’t turn on . The stand by light flashes 5xs and I then hear a faint click. I have taken off the back of the tv and none of the capacitors are bulging. I disconnected the main board from the power board and plugged it in and could see light coming through the screws. I am assuming that this means the power board is good. Should I try replacing the main board? The model # UN65JU670DFXZA.
I unplugged the T-con from the main board and it lights up. Do I need to replace the T-con board?
Esta é uma boa pergunta?
3 comentários
Hi there I have a similar issue I think with my tv... model number UN55D6500VFXZC ... standby light is on and working, try to turn tv on and standby light flashed 5 or so times and the I hear a click.... it’s like it’s stuck in this cycle of the standby light flashing and the faint click... unplug tv (which is plugged into a surge protected power bar) and tv will actually continue to have the standby light and faint clicking will continue for about 30 seconds to a min even when completely unplugged. Anyone have any suggestions???
por Jennifer Anderson
Hi my samsung uhdtv 50 7 series nu7090 power button red light is blinking and won't come on
por andyhintzen98
The power supply unit needed replacement (used amazon) after seeing nothing on the screen and just a red flashing light on the indicator. Worked Great
por jack Tide
