Ir para o conteúdo principal
Mid 2013 revision to the Xbox 360 line of game consoles, featuring 4 USB ports and built-in Wi-Fi connectivity.
89 Perguntas Visualizar todos
Red ring fix for xbox 360 E?
When I turn on my Xbox the fan immediately goes crazy and then after 5-6 seconds the button turns red while the Xbox is not being displayed on the screen. Is there a fix for this for the Xbox 360 E?
Esta é uma boa pergunta?
Pontuação 9
Adicionar um comentário
2 respostas
Pergunta mais útil
I have xbox 360 E .
if you have this problem RROD .
  1. turn off the console.
  2. Remove the HDD. clean it with air blow.HDD Socket / Console HDD Socket.
  3. put it back. and start console.
if your console not remove the issue. use 2nd step.
1 . Remove all cables from console. include HDD.
  1. Put the console for 10 to 12 Hrs.
  2. after 10 to 12 hrs. connect all cables and HDD.
  3. start console and press Syn Button + eject button for 2 /3 second.
  4. than press the power button.
Esta resposta foi útil?
Pontuação 2
2 comentários:
What u mean by put the console for 10 to 12 Hrs?????
por
How do I fix the red ring of death for the Xbox 360 E? Nothing works!
por
Hi Erik,
Here is iFixit's RRoD Fix Kit. Hope that helped!
Xbox 360 Red Ring of Death Fix Kit
-Cooper
Imagem de Xbox 360 Red Ring of Death Fix Kit
Produto
$29.99
Pontuação 0
Adicionar a sua resposta
Erik Rodriguez será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 86
Duração total: 17,427
