Ir para o conteúdo principal
Model M7886 / 450 MHz or 500 MHz PowerPC 7400/7410 (G4) Processor
Why does my Cube take for ever to power on
Hi guys,
so recently I‘ve noticed that my Cube takes really long to turn on. Like minutes. Also when I put the cable into the outlet it takes a couple of minutes for the green led on the bottom to turn on. Does anybody have an idea what could cause the problem?
Also I might have to note that I live in Germany so we have 230V mains voltage, if there is any known defect in European Cubes.
Thanks for your help!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@lambda possibly running into issues with either your power brick or your DC-DC board. You do want to check the output of those with a meter and see. Use these guides Power Mac G4 Cube and teardown to check things over.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
--- será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 100
