Pular para o conteúdo principal
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
566 Perguntas Ver todas
Replacement of Harddrive: SSD with SATA 3
Hey there,
I have read that the new OCZ Vertex3 SSD will have an SATA 3 6.0Gbit/s connection. Does the SATA controller of the new MacBook Pro series (8,1 8,2 8,3) supports SATA 3?
Thank you for your support!
Sebastian
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Kit de Reparo de Bateria do MacBook
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
4 Soluções
Solução escolhida
This article should give you all the information you need on Macs and support for SATA 3, USB3, 6 gbps and SSD support: http://www.stationstops.com/2010/02/17/a...
Esta resposta foi útil?
Pontuação 2
I believe that the harddrive will work regardless if the SATA controller is SATA 3 or not, it just won't at its full speeds. That SSD will still provide a very nice performance boost though. SATA 3 is backwards compatible
Don't forget to mark whichever answer satisfies your question, if any.
Pontuação 1
Comentários:
Hi Skippy722,
Thank you for your reply.
The performance of a SSD drive with SATA 2 is quite nice. I have currently installed a Vertex2.
But I was wondering if I can reach the full speed of 550MB/s with a Vertex 3 SSD via SATA 3 in the new MacBook Pro.
por
Via SATA3, yes you will see full speeds, in a perfect world. There are other issues, so those numbers are just the absolute maximum that the drive can do.
por
The article cited by mayer is about last year's notebooks. Apparently the HDD shows as SATA 3, but not the DVD drive (that may be a SW limitation; a similar situation happened with SATA 2)
http://forums.macrumors.com/showthread.p...
Pontuação 0
Hi,
My macbook late 2009 has sata-2 hard drive interface. I got a SSD SATA 3, Kingston Hyper SSD 120. Will it work if I connect the ssd sata3 with the sata2 connector inside my macbook?
Thanks
Adriel.
Pontuação 0
Adicionar a sua resposta
Sebastian será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 24,686
