Ir para o conteúdo principal
Flash unit for use with Nikon Cameras
12 Perguntas Visualizar todos
My flash does not fire, even though it turns on and shows ready
I have a SB600 with new batteries and am using it with Nikon D300s. The flash turns on, shows ready but does not fire. I have tried turning it on/off, turned camera on/off. It just fails to fire.
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Any chance you dropped it or the old batteries "leaked"?
por
Thanks! No, I never keep batteries inside. And I did not drop it. The test fire button does not work.
por
Have you tried another flash on the camera, just to rule out the hot shoe? Also it is possible that the actual bulb has burned out.
por
Adicionar um comentário
1 resposta
Solução escolhida
try pressing the test fire button or shorting the terminals and it should flash (while not connected to your camera). If it does, then you know your flash works, if not try looking into your camera settings.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
SM123 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 37
Duração total: 3,305
