Ir para o conteúdo principal
This is the device page for the Samsung Galaxy J7. The OS that comes stock to the device is Android OS v5.1.
170 Perguntas Visualizar todos
Ive dropped my phone in water, everything works but the on/off button
I dropped my phone in water and immediately took steps to dry it, after a small amount of time, I powered it back on and everything seemed to work except the power button. I can still turn it on because of the home button but it only turns off on time-out. Looking for a solution to this problem. Any help is appreciated.
Thank You
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
redbubba02 besides the great answer by @j0vian I suggest that first you do not turn on your phone, charge it or try to connect it in any way. Remove the battery from the phone to minimize further damage. After that completely disassemble your phone by using these guides. Using 90%+ isopropyl alcohol, clean your phone by following this guide. It was written for an iPhone but all the points still apply to your phone as well. While cleaning, check for obvious missing or damaged components. you can always post some images of your boards etc. with your question so we can see what you see. Use this guide Adicionar imagens a uma pergunta já existente for that. Once it is properly cleaned, replace the battery and reassemble your phone. Only after it has been fully cleaned can you properly troubleshoot. Liquid damage is the hardest to troubleshoot and the most difficult to repair since virtually any part/ component may be involved. Your could simply be a shortened power button but it could as well be a failed component on the power circuit.
Imagem de iPhone
Guia
Repairing iPhone Liquid Damage
Nível de dificuldade:
Difícil
1 - 2 hours
Imagem de iFixit
Guia
Muito fácil
2 - 5 minutes
Esta resposta foi útil?
Pontuação 3
2 comentários:
@oldturkey03 ahh shucks.... thanks and have a happy new year and quit playing on the computer. :-) You should be having fun...
por
@j0vian you are right brother. Wishing you and yours a Happy New Year!
por
The steps to a water damaged device it to fully disassemble it and clean the board with 92% rubbing alcohol and a toothbrush. if the device is powered on before all moisture has been removed then parts may have to be replaced. But the funny thing with liquid damage is that it can do very funny things afterwards if not immediately then later on.
Pontuação 2
Everytime I tried to turn my phone off it not working
Pontuação 0
Adicionar a sua resposta
redbubba02 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 38
Duração total: 2,342
