Ir para o conteúdo principal
This instant camera from Fujifilm now boasts a slimmer and lighter body than previous revisions. The Mini 8 helps the photographer by alerting them the recommended aperture. It also has a High-Key flash mode which helps the photographer attain soft portraits for a stunning look.
355 Perguntas Visualizar todos
My Instax Mini 9 film keeps coming out black.
I just got the camera and the first set of film came out black so I thought the film was ruined. I bought a new pack and put that in and it still comes out black. The flash goes off and I had it on the right settings.
Esta é uma boa pergunta?
Pontuação 5
3 comentários:
I have the same issue. Has anyone figured this out!?
por
My intax mini 9 pictures are dark at the top of the photos.
por
My instax mini 9 pictures are dark around the edges but normal exactly where the flash was
por
Adicionar um comentário
4 respostas
I'm having the same issue and unfortunately I don't have an answer but I would contact customer support so you can replace either film or the camera if you are eligible for the warranty. Thats what I am currently doing and I wish you all the best!
Esta resposta foi útil?
Pontuação 0
I had this problem!! And I couldn’t find the solution online. It wasn’t the shutter in my case. There is a piece of black tape inside the camera, above the lens, blocking the exposure. Peel it off- problem solved for me. Hope it works for you too!
Pontuação 0
5 comentários:
was it a above the lens just below where the back of the camera opens? I have this same problem and there is a little piece of tape there but it seems like its supposed to be there
por
Where exactly the tape is?
por
Inside the camera, below the film.
por
hmm mine looks like it should be stuck on as well. Did it look like that for you Molly?
por
Wait where exactly is the tape? I saw a tiny black tape in the bottom of the film installing area in the back of the camera(it's stuck to the camera) I peeled it off but I don't know if that's the right one. >-<
Also, can anyone just send a photo of where the black tape is in their camera please? ._.
por
I have seen people who had this problem with the instax 8 say it was due to a black piece of tape above the lens that messes with the exposure so if you find something similar try removing that!
Pontuação 0
I was told it's problt cause of not enough lighting on the camera and make sure not to shake them
Pontuação 0
Adicionar a sua resposta
Alyssa Cooney será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 19
Últimos 30 dias: 61
Duração total: 15,599
