Replacement home button doesn't work
I replaced a iPhone 6 screen & the screen/camera/Speakers are all functional but the home doesn't work at all - nothing. My client came to me with out a home button so I cannot test the original. Is the new button defective or is the software glitching out because it hasn't had a home button in a while.
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 1
Comentários:
A replacement home button should function the same as a regular home button with one exception-fingerprint ID will not work. As far as glitching? A hard rest should solve the problem. Ensure the replacement is for the six.
por
Im getting no functionality at all - I can't do a hard reset without a home button
por
You can do a hard reset if you turn on Accessibility. It will place a home button on your screen. Then just find the option to restart the phone.
por
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
4 Soluções
Solução escolhida
I would guess the home button to be the defective part.
Esta resposta foi útil?
Pontuação 1
Comentários:
I will change it out and see. will update. Thank you
por
Resposta Mais Útil
Could be homebutton, but could also be the longflex running along the screen
Pontuação 2
Comentários:
The screen is brand new would that make the new screen defective?
por
its not the actual screen but the metal plate with the ribbon thats attached to the back of the lcd
por
What Daniel said. If it came with the screen, then even higher chance that it does not work as it is likely a cheap part
por
The button was defective - replaced the button (again) and it was fine
por
Touch ID isn’t functional after an screen repair if the home button is replaced.
Pontuação 0
Comentários:
I’m not looking to use Touch ID - just use the button for its other functions
por
ensure the cable on the thermal plate is working, try another cable-ensure the socket where the home button is plugged into isn't damaged- try a replacement home button know to work with the iphone six remember the touch id will not work -all other functions should.
Pontuação 0
Adicionar a sua resposta
jeanise será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 55
Todo: 409
