Ir para o conteúdo principal
Repair and disassembly guides for Asus tablets.
428 Perguntas Visualizar todos
I dropped my Asus Tablet into water and it won't stop rebooting.
I dropped my Asus Tablet into water, can it still be saved? It won't stop rebooting. I have put it into rice and drying bags and it is currently drying. It won't stop rebooting, and i cannot turn it off. It is doing the same thing as my old Asus tablet. do you think it is still able to save?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Hi @escapism ,
What is the model number of your tablet?
It may be able to be repaired. It depends on what damage has occurred and whether it is economical to do the repair
You need to open the tablet and disconnect the battery from the systemboard to minimize any further damage. Once the battery has been disconnected, DO NOT reconnect it and try to turn on the tablet again until it has been cleaned and repaired, as you will only be compounding the problem.
Also while rice may be good to eat it does nothing to fix the problems caused by corrosion
Don't Put Your Device in Rice. Here's Why...
Water, electronics and electricity are not a good mixture. The impurities in the water cause corrosion whilst the water itself is a conductor of electricity and allows current to flow in areas not catered for in the circuit design of the tablet
You need to clean off all the corrosion and disperse any remaining water by using IPA 90%+ (Isopropyl Alcohol - available at most pharmacies). Do not use "rubbing alcohol" as it is usually only 70% or less, may contain scents and is not as effective.
The link below may be of some help in the cleaning process of the components affected by the water and corrosion.
Electronics Water Damage.
If the above process seems to daunting, I recommend that you contact a reputable, professional laptop or mobile phone repair service experienced in water damage repair and ask for a quote.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Yes! absolutely , but surely the other parts is for replacement.. try to open your tablet and you will see lots of corrosion. try to clean the board using brush and alcohol and try to reflash the stock rom. using SD card..
download your stock rom here....
https://www.asus.com/support/#
Pontuação 1
Adicionar a sua resposta
Cassie será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 757
