Ir para o conteúdo principal
Released August 2003. An expensive, but high-end laptop of its time.
Power won't stay on.
When i turn the power on the power light comes on then goes right off, what could be the problem.? I took out the ram and cpu and it still does the same thing. Can you help ? Tha same thing is happening with my Dell Inspiron 6000.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Plenty of things can cause the issue, and unfortunately most of this requires trial and error.
if your device is able to boot while plugged in, and battery removed, its simply a battery problem. however, you could also have a bad charge port, that is not giving current to the device, so it is not charging. You could have a problem with a board level component as well. some devices have a failsafe, that if it does not sense a fan, it will prevent itself from booting.
these are some of the more comon reasons devices wont start.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Greg Smith será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 117
