Panasonic TV TX-42ASX659 not turing on
This post was not in the right category and I wasn't able to move it in the right one, so I posted a new one:
Esta é uma boa pergunta?
Hi @jonasschade, if possible open up the TV and check on the power board inside to inspect for any possible bad capacitor.
Esta resposta foi útil?
@jonasschade looks like you are losing your backlight. You do want to go ahead and post some images of all of your boards with your question. Use this guide Adicionar imagens a uma pergunta já existente for that. It will allow us to see what you see. Your model appears to be a European model so if you can, check for a chassis number on the back cover. Let us know what it shows. This could be a power board/LED driver issue as well as a T-con board issue.
Here is the schematic for the power board. TNPA6011+Panasonic+LA51.pdf
There is a link to a imgur album in the original post already, where pictures of all the boards can be found. https://imgur.com/a/zC7xa
The Serial Number is NP-4620820. I hope you meant that by chassis number, if not can you tell me where I can find it? This and the Model Number (which is the TX-...) are the only two I could find on the label on the back.
@jonasschade check the fuse on the T-con board (you identified this as your panel controller) for continuity first. Then (with your set turned on so be mindful of shortcircuiting) the voltage on it. Multimeter to VDC Black probe to ground and red probe to either contact of the fuse. What you getting?
@oldturkey03 just to make sure this is the fuse (see pic) correct? https://i.imgur.com/eSDVx0p.jpg
@jonasschade yes that is it. Sorry got busy:-)
This is problem ... I change one backlight panel and power on TV ..
All is OK :)
I replaced the PSU which fixed the voltage values, but the TV still doesn't turn on, so I guess it's a Mainboard issue but I'm far from an expert...
I'm thinking about buying a new MB, but I haven't until know.
Problem is in the backlight. One led is death.
This motherboard has software problem. Probably crashed or erased emmc causes this problem. If you count the number of blicks, it makes 13 times which means software issue.
I have the same problem. And thinking to buy a secondhand motherboard. I could not install the software from usb port.
If someone please help.
Hello,
If you want install a new software you need a jtag and solder wires from jtag to motherboard and get from the net if found the rom bin file and flas it again.
I have the same problem i would like to buy first the jtag but i am not sure if there is a correct bin file. if someone has done it before please help.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 400
