Ir para o conteúdo principal
Second of its generation, released in November, 2011, the Sony SLT Alpha-65V is a SLT (Translucent Mirror Technology) camera with a Sony Alpha/Minolta lens mount.
12 Perguntas Visualizar todos
Powers on but won't stay on or doesn't power up at all.
Powers on intermittently but powers off by itself. Confirmed good battery and A/C power supply. Switch, motherboard?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Using the Sony battery, it will power up but will not power down with the switch, nor will it power back up. Screen goes blank. If I release the battery and reinsert it it will power up. I doesn't matter if I use the battery or A/C power adapter. I'm leaning towards motherboard although I have my questions about the On/Off switch.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Check the internal battery contacts and clean with qtip and alcohol...I have cured a similar problem because oil contaminated the contacts.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks but I looked at those. I'm guessing the problem is with the logic board. I will post on here if that is the solution. Thank you.
por
Okay..it does sound more like a dry joint leading from battery unit to switch or board....forgot to mention...I take it you are using the bonafide battery from Sony?Because they have a chip inside and third party batteries will power up and the camera software detects they are not Sony and so switch off the camera.
por
Adicionar a sua resposta
HITGFRY será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 357
