Use a 5c or 5S battery temporarily for data recovery
Is it possible to use a 5c or 5S battery temporarily to recover data off a iPhone SE? I have no problem hard wiring it if needed instead of using the battery connector
Esta é uma boa pergunta?
Sure! The connectors don't match but it's still the same output voltage; just solder some small jumper wires. Double check with a voltmeter to insure you have the polarity right.
Another alternative is to use a DC power supply if you have access to one.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 44
1 comentário
I do have access to a DC power supply. All I need is +/-? Not the gas gauge or anything attached?
por jjones0377
