Ir para o conteúdo principal
This product is a 27-inch LED display with a resolution of 2650x1440 pixels released by Apple on July 27, 2010. It has the model number A1316.
78 Perguntas Visualizar todos
How to remove Glass to clean dirt?
Need to remove glass to clean dirt from screen, as well as what is best to clean it with...Thanks
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
This guide is a bit more detailed on removing the panel. It is for an iMac, but the procedure should be pretty much the same.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Here's the tear down. This will show you how to get into it. There's a video also. Use a non-ammonia glass cleaner such as Sprayway, applied to a very soft cloth. Do not spray cleaner directly onto electronics.
iMac Intel 27" EMC 2309 and 2374 Teardown
Pontuação 3
2 comentários:
I couldn't find that guide. I've voted to move your comment to an answer.
por
Andrew, if you'll form your link into an answer, I'll delete mine
por
Adicionar a sua resposta
Mark Sparks será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 4,609
