How to remove Glass to clean dirt?
Need to remove glass to clean dirt from screen, as well as what is best to clean it with...Thanks
Esta pergunta é pertinente?
This guide is a bit more detailed on removing the panel. It is for an iMac, but the procedure should be pretty much the same.
Esta resposta foi útil?
Here's the tear down. This will show you how to get into it. There's a video also. Use a non-ammonia glass cleaner such as Sprayway, applied to a very soft cloth. Do not spray cleaner directly onto electronics.
I couldn't find that guide. I've voted to move your comment to an answer.
Andrew, if you'll form your link into an answer, I'll delete mine
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 4,601
