Why is my screen flickering?
Hi,
So I ordered a new screen for my iphone 6 from ebay, I installed it properly but it doesn't work well. Everything else works perfectly fine, camera, sensors, speaker, etc, even touch screen, but some weird flickering and pixels appear all the time, plus the resolution seems way lower than it was normally on my iphone, the edges aren't sharp anymore on my screen. Do you think the screen came in faulty or did I do something wrong? Here are two photos I took of the screen just after replacement:
https://www.dropbox.com/sh/0cip2c211tmpl...
Update (11/28/2017)
Hey, that's exactly what I did several times, all the cables are plugged in properly, or so I believe, that's my first time replacing a screen on an iPhone. Could it be my fault that I maybe pulled some cable too hard, bent it the wrong way or something?
Esta é uma boa pergunta?
2 comentários
There's no way to check with the original one as it broke all the way when my phone fell on the ground, the glass shattered and the lcd was only showing black screen with a couple places where pixels were just going nuts showing different colors and stuff.
I ordered a new one and it's supposed to come in tomorrow, if this new one doesn't work well too I can assume the pins on the motherboard are damaged and there's no way of fixing it right?
por [deleted]
I have the same problem but when the phone is open there is no problem but when it is secured it always flickers
por Its me
