Ir para o conteúdo principal
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
146 Perguntas Visualizar todos
I dropped my phone and now the power button doesn't work.
My phone fell face down. the screen worked fine, but the power button wouldn't work. I could only turn the phone on and off by using the screen. I tried to take the battery out so it would turn off all the way, but now it won't turn back on.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Hey check out this fix
Works quickly .
http://dillysano-mymakemoneydiary.blogsp...
por
Adicionar um comentário
1 resposta
Solução escolhida
When it impacted the ground it could have severed the cable going to the power button. You will have to replace that if you want to fix the powering off problem. Sorry i don't have any other options but thats all you can really do in this case.
Good thing is that cables cost very little so thats a plus.
Esta resposta foi útil?
Pontuação 1
2 comentários:
thank you. I was thinking that might be the only option.
por
how much tho?
por
Adicionar a sua resposta
ash será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 17
Últimos 30 dias: 60
Duração total: 4,732
