Ir para o conteúdo principal
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
Ipad restarts every 3 minutes after complete rebuild.
Hi everyone.
I had a customer who's son broke their ipad. From initial looks, it was the LCD, Digitiser and chassis which had broken.
First I established that if I can turn on the Ipad and check its functionality I would swap out the LCD and Digitiser to do so which worked well and I tested that everything was in working order. The customer advised me that he would like the chassis changed as he couldnt deal with the bent chassis anymore.
I completed a chassis change but the original battery didnt survive the swap over. I therfore purchased a new Ipad battery and before attempting sealing the Ipad thought ill make sure everything works.
My main problem I have now is that the Ipad starts up and after approximately 3 minutes it would restart.
Other indications:
1)when the Ipad is on, and on charge, I get a charge symbol but percentage does not go up.
2)When ipad is Off and on charge for a while and switched back on, Percentage does increase.
3) Continually restarts regardless of whatever I do.
I personally think its a battery fault for the restart that I may of not allowed it to charge properly first before switching on.
My main objective is to stop the restarting every 3 minutes.
Thoughts?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Probably a bad battery.
Esta resposta foi útil?
Pontuação 2
4 comentários:
My suspicion also.
When a new battery is installed and charger cable is inserted, the iPad starts up, Is it best practice to switch it off immediately and just leave it to charge?
por
I usually just charge up the iPad as normal.
por
I am going to acquire a new battery, Is there a pretest I can do before installing it with a voltmeter to ensure it's going to give me the full beans?
por
Well with a digital multimeter, you can really only test if the battery has sufficient charge or not. 3.7-4.2 voltage range.
por
Adicionar a sua resposta
Matt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 2,367
