How do I fix it?
I had to move my washer and now the lights come on but it don't fill up to wash. HELP!
Esta é uma boa pergunta?
If you are comfortable doing so. Most of the time your water valves are on the back panel of your washer. Can be very complicated. Or very simple depending on manufacturer. To remove back of washer. Get access to valves. Check power valves. If you have power At the valves. Somehow, you damage the valves. Replace them. Should fix the problem I would tend to believe. That you've knocked some plug loose. On the computer That controls the water
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 33
3 comentários
You'll have to give us some more details. I.E. What brand is the washer?
por George A.
This question was migrated from http://meta.ifixit.com/Answers.
por iRobot
Hi @mrsdill ,
Have you connected the washer's water hoses to the appropriate water taps and have they been turned on?
por jayeff
