How do I replace the seals in the Thermoblock?
How do I replace the seals in the Jura Avant-garde S8 Thermoblock? The halves need to be separated.
Esta é uma boa pergunta?
Look here - but you need to know some german words, or just use Google translate. The right guide is called "Revision des Thermoblocks"
Esta resposta foi útil?
This is wonderful! On page two of the guide, a tool that looks like a Nut Driver is used for the center bolts. My Thermoblock looks like it uses hex-head bolts and I am not sure I can find a thin Nut Driver to fit in the hex-shaped recessed hole. I will search.
The two bolts should be normal ones of 7 mm. The outer screws should be a Torx ( or Allen, don't remember?)
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 138
