Ir para o conteúdo principal
Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
138 Perguntas Visualizar todos
MyKenmore electric dryer spins but will not dry clothes
My Kenmore electric dryer spins but will not dry clothes
Esta é uma boa pergunta?
Pontuação 0
1 comentário
My Kenmore electric dryer spins but does not dry clothes
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Cause 1
Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer’s heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jim Haffey será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 66
