Ir para o conteúdo principal
Repair guides and support for cars manufactured by the German automotive company Audi.
82 Perguntas Visualizar todos
Audi Q7 turned off and wont crank
Hello short story i was driving normaly took a turn and then steering wheel got heavy the car turned off, messages appear in the screen saying alternator not charging the batterie, eps malfuntion, gearbox limited , and the car wont even crank all accesorys worked but they where dimming so i replace the battery but nothing any tips?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
it was the ecu got water damage dont know how but it did
Esta resposta foi útil?
Pontuação 0
2 comentários:
How did u find out it was your ecu?
por
ecu is on the passanger side open the hood and under the wiper blade there is a black cover
por
Following are the common solutions to kickstart your Audi Q7 once again:
- Battery Replacement
- Fuel Pump Replacement
- Ignition Switch Replacement (Electrical)
- Ignition Lock Cylinder Replacement
- Starter Replacement
- Camshaft Position Sensor Replacement
- Crankshaft Position Sensor Replacement
- No Start Diagnosis
Pontuação 0
Adicionar a sua resposta
carlos será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 24
Duração total: 2,026
