Ir para o conteúdo principal
An E-Cigarette vaporizer is a device used to heat a substance, such as cannabis or tobacco, to a temperature at which it releases a vapor that can be inhaled. It is a reusable alternative to traditional smoking.
121 Perguntas Visualizar todos
How to open eleaf ikuu i200
the mod is is pasted without a battery replacement slot, the battery is internal.
He constantly shows the error "charging error"
How to Replace them.
The factory reset does not work
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
There are two screws underneath the stickers.
Peel back Bottom curved corner farthest away from trigger side. You will need soldering iron to replace 2x 18650s.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
helex será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 4,602
