Why isn't my brush roll moving?
My brush roll won't move because there is something stuck.
Esta é uma boa pergunta?
Open up your vacuum cleaner and check the belt. It likely has snapped or snagged and needs replacement.
Esta resposta foi útil?
ok, I ll try your recommendation, but still need the replacement that goes closer to the bus . The roller cover please. Would you help me?
the brush is ran by a belt. check to see if it has come off. you will have to remove the bottom but it is usually a phillips head screwdriver to do so.
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 560
1 comentário
I have taken the brush assembly apart and cleaned any buildup which was minimal. It will spin sporatically. Most of the time not.
por blackbear524
