Ir para o conteúdo principal
Vibrator,loudspeaker and headphones not working
I accidentally dropped my phone from 3 feet, then my volume got damaged and struck inside. I have opened my phone and removed volume buttons and somehow I fixed(never operated with phones before—used online videos to fix). Now the Vibration,headphones and loudspeaker are not working but charging port is working. Can anyone tell me the reason?
Thanks in advance
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Make sure your sound settings are not turned all the way down. Since you removed your volume buttons, you should be able to change it in settings.
Esta resposta foi útil?
Pontuação 0
Thanks for your quick reply. All the sound settings are good. Do you have any other suggestion?
Pontuação 0
1 comentário:
If you opened up your phone and weren't properly grounded, it is very possible you caused electrical damage to your logic board. Unfortunately, that's where my expertise stops, so I'm just guessing now. Have you tried bluetooth? also, there's a little slider above the volume buttons, make sure its turned up or down or whichever way isn't red.
por
Hello people
After my iphone 6 Gold dropped on the floor, Charger not working, No sound working even with earphones.
Help out
Pontuação 0
Adicionar a sua resposta
Satish Boppana será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 259
