Ir para o conteúdo principal
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Perguntas Visualizar todos
Does the copper-tape surrounding the digitizer have to replaced.
I have disassembled my iPod for a front-panel replacement, and am unsure if the copper-tape surrounding the digitizer must be replaced.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
5 respostas
Solução escolhida
I don't think that it is strictly required when replacing the front panel - it might be there to eliminate RF interference around the digitizer connector. We have a 4th Generation Touch that we use for testing components that doesn't have the tape around the connector and it operates just fine.
Esta resposta foi útil?
Pontuação 2
I accidentally ripped the copper tape connecting the center plate (which houses the home button) and the camera and now neither of my cameras work.../: help please
Pontuação 0
Yes because if you don't replace the copper tape your wifi antennae will not work properly, thus you will have to sit next to your wifi router just to get 2 bars.
Pontuação 0
were can we purchace the copper tape???? does any copper tape work??
Pontuação 0
Tearing the copper tape will not effect wifi or the cameras it's purpose is for grounding..
Pontuação 0
Adicionar a sua resposta
Elijah Ellis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 3,055
