Why won't my LG Dare charge?
will not charge
Esta é uma boa pergunta?
will not charge
Try plugging the phone into your computer. It seems like your phone uses a Micro B USB.
If it doesn't work it may be the USB port.
Also, try another charger. I can't find any external battery chargers so thats out of the question.
Esta resposta foi útil?
+ also try another port and cable
Will it not charge on neither the wall charger or the USB charge from the computer? Follow Gabe's advice first. But do consider how old your battery is and that the battery may be not holding or taking a charge. Also keep in mind that the LG Dare had issues with the pins of the charging port. Make sure that the pins are making contact and that they are not bend etc. Good Luck
connter problam
and charge ic problam
charge ic problam
i was having the same problem charging the vx9700,but i pluggeg the phone into my computer usb port and downloaded the phone drivers and its charging from that ok
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,444
