Ir para o conteúdo principal
The first generation Mazda MX-5, or Miata.
20 Perguntas Visualizar todos
Timing belt broke while driving
I have a 1997 Mazda Miata. The timing belt broke and I want to know if there could be any other extensive damage to the engine before I have it repaired. Is there any way of determining other damage?
Thanks;
Pete
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
From what I've been able to see on line in miata forums these older miatas are non interference designs that won't eat the valves when the belt turns loose. Removing the valve cover and manually turning the cams can confirm this... If any valves show massive clearances at any point of rotation it is of course indicative of bent valve stems. Naturally if you encounter serious resistance trying to turn a cam you should refrain from forcing it.
Esta resposta foi útil?
Pontuação 4
@fullcircle15 the Miata engines are non-interference engines. You should not have any piston/valve damage.
Pontuação 4
Adicionar a sua resposta
peter shea será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 30
Duração total: 2,941
