Pular para o conteúdo principal
Liberado em abril de 2010 com as opções de processador i5 de 2,4, 2,53 GHz Core ou i7 de 2,66, 2,8 GHz Core
601 Perguntas Visualizar todos
pro gets really hot underneath
My Pro gets very hot especially when plugged in on the same side underneath...Should I replace the fan and how do I know which fan to purchase...left or right?
thx
J
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
Kits de reparo de android
A new screen or battery is one kit away.
Comprar agora
Comprar agora
3 Soluções
Solução escolhida
Probably one of two issues both dealing with the heat sink.
First you can try replacing the thermal paste.
Second is that the heat sink is liquid filled and can develop a leak (these get very hot), replace the heat sink. Look for an oily reside on the logic board around the crimped ends of the sink.
MacBook Pro 15" Unibody Mid 2010 Heat Sink Replacement
Esta resposta foi útil?
Pontuação 1
Comentários:
@mayer Wow, I never knew the heatsinks in these were liquid filled!
por
@vehiclefreak409 Apple started this around 2008 with the MacPros. Copper is expensive. Copper weights a lot and in laptops they are fighting for fractions of an ounce to keep the weight low.
por
Resposta Mais Útil
If you don't have an apple store to go to, or just low on time, here is some apple support regarding heat.
My MBP does get hot too, usually when I'm utilizing the graphics cards high (i.e. HD youtube, certain games).
I have a stand with a fan that I use to assist with the cooling, you can purchase one on Amazon
Good luck
Pontuação 2
Comentários:
Apple considers this a "legacy machine" obsolete. They won't help you only try to sell you a new one.
por
I do not disagree with you there.
por
This is pretty normal in my experience. The more resource heavy applications will make the laptop noticeably warmer. its fine unless its hot enough that it burns you, then you may want to check itout. and yes, the area around the charging port does get warm easily.
Pontuação 1
Adicionar a sua resposta
Jayne Tutalo será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 70
Todo: 2,509
