Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
124 Perguntas Visualizar todos
Any way to make it work with display port?
Hi all,
I've got computer build on mini itx Gigabyte GA-Q87TN motherboard with normal display port and HDMI.
Recently I've purchased Thunderbolt Display (as I really like the design), unfortunately I read some misleading posts in Internet like:
"When you plug the Thunderbolt display into a mini-DisplayPort of a PC, it acts just like every other screen that is on the market.But NONE of the USBs, mic, camera, Ethernet or speakers will work, as they require a Thunderbolt connection."
"Thunderbolt ports are divided into 2 pipelines, one for data and the other for video.Going from the quote it should work with the video pipeline with no issues, but with no support for any of the external inputs (FW800, USB, Ethernet port)."
Unfortunately screen works only with original Apple MacBook with Thunderbolt display... so I started looking about an solution
First I was thinking about Thunderbolt card, but it won't work as my motherboard don't have "Thunderbolt add-in card connector" :/
Now I'm thinking about something similar to this: https://www.youtube.com/watch?v=gwzOVysJ... - do you know maybe if there is any way to do this with Thunderbolt display, and will it support it native resolution?
Or is there maybe any other way? Or should I try to sell it :(
Thank You
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
Kits para o Nintendo Switch
Um reparo rápido para reiniciar o jogo
Confira kits para o Nintendo Switch
1 Resposta
Pergunta Mais Útil
without a thunderbolt controller, it wont work with Mini DisplayPort unfortunately.
There is an older version of the 27” display that came with Mini DisplayPort, but they are different to the thunderbolt model
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Tommy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 59
