Ir para o conteúdo principal
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
70 Perguntas Visualizar todos
Why can't my Dell Inspiron 1525 charge the replacement battery?
Battery doesn't hold any charge.
Esta é uma boa pergunta?
Pontuação 1
3 comentários
Is it a new battery that you're trying to use?
por
No, it's an old replacement battery and the electrical cord is used as well. Has been worked on prior times, not me. Trying to save the laptop since it's my only backup and my Mac doesn't have microsoft cause I can't afford to buy the approved programs.
por
Use this : Dell AC Adapter LA90PM130
por
Adicionar um comentário
3 respostas
Solução escolhida
Ok so what I would do is look for a replacement battery on Amazon, like this one:
Dell Inspiron 1525 Battery - Amazon
Try using that, and it should work just fine.
- Jasen
Esta resposta foi útil?
Pontuação 3
if Ur useing a new battery then u probably need to replace the charger port
Pontuação 0
I have replace the battery & also replace the charger port , then same problem could not charging the battery…..
now what can I do…..?
Pontuação 0
Adicionar a sua resposta
Maria será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 408
