Ir para o conteúdo principal
Rectangular Form Factor / 16 GB capacity / Announced September 12th, 2012
iPod doesn't turn on
I have an iPod Nano 7g and it doesn't turn on. Just a black screen. I have tried the home/sleep button + home button but that doesn't work. I have tried to turn it on. Nothing. I have left it charging for many many hours. Nothing. I have tried the recovery mode and iTunes method. Nothing. I have tried other cables and charger.
The iPod has not been dropped and no signs of physical damage. I guess the battery is dead and needs to be replaced.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Sounds like one of three things: screen, battery or logic board. Try replacing the battery, and see if it powers up. Before you do, does the device get hot while it is charging, meaning the power is reaching the battery?
Esta resposta foi útil?
Pontuação 0
1 comentário:
My device is getting hot, but won't turn on. What could it be?
por
No the iPod doesn't get hot while charging it. In fact, I don't think the iPod is charging at all. Which I conclude is the battery.
Pontuação 0
1 comentário:
I've got the same problem Does yours show up on itunes when connected to the computer
por
I’m sure you put it in DFU/Disk mode, my uncle has a channel on YT for ipods
Update (01/10/2021)
I’m pretty sure you put it in DFU/D.I.S.K Mode
Pontuação 0
Adicionar a sua resposta
jkbmjp será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 23
Ao todo: 1,788
