Ir para o conteúdo principal
O Moto G é o smartphone com preço econômico da Motorola. Ele possui todos os recursos que se poderia desejar em um smartphone, pela metade do preço. Números de modelo XT1032, XT1033 e XT1036.
Why my battery is decreasing while charging?
I have Recently changed my battery. When I went to bought new one the new battery was showing only 2.2 volts so he started charging the battery and when it was 3.8 volt my phone starts and it shows 17% battery when I came back to home and started charging my cell phone it was continuously decreasing the battery phone was still charging what is the issue can you please help me.
I have no original charger I am using a Vivo charger with 5 volt and 1 ampere output.
And when I am charging my cell phone while switch off it is increasing the battery percentage.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi!
Try using a more powerful power adapter, you current one may not supply enough power to your phone. Another thing to check is the cable. See if the problem occurs again if you use a different cable.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Sumit Prajapati será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 19
Ao todo: 3,489
