Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
601 Perguntas Visualizar todos
Can I upgrade my new MacBook Air 2017 from 128gb to 256 gb ssd
Hi, I have a MacBook Air 2017 and I want to upgrade it's ssd from 128gb to 256 gb. Can I do that? And, I also have crucial 2.5 256gb ssd drive(is it compatible with Apple Mac air). Which tools I will need to do this, thanks.
Esta pergunta é pertinente?
Pontuação 9
3 comentários
If you use an aftermarket part, won't it void the warranty?
por
what warranty at this point, they dont sell this model anymore, its been 3 years since this has been discontinued plus its now illegal to void warranties in this way since the FTC is now enforcing the Magnus & Moss Warranty Act
por
If there may be any app that work ideal in time period of excellent and subtitles, it’s not anything cucotv apk. Yes, you could now watch all of your favorite movies and collection in your very own language. You have the choice to select the language of the subtitles at the start of the app release. https://cucotv.com/ Otherwise, you may visit settings of the app after which go to subtitles phase to choose the language. So, you have got one of a kind methods in which you could pick and configure the subtitles of any movie or a show.
por
Adicionar um comentário
5 respostas
Solução escolhida
Yes you can upgrade your current SSD to a larger unit. Here's the part you'll need to get:
FYI: the newer 2017 model is only a CPU swap out to a slightly faster chip. Its the exact same system otherwise.
Esta resposta foi útil?
Pontuação 8
4 comentários:
Hi! I believe it's necessary to back up whole system before changing SSD. Can you explain how please?
Thanks
Tomas
por
There are a few different ways you can do this:
First create an OS installer thumb drive following this guide: How to create a bootable macOS High Sierra installer drive This will allow you to install a fresh OS on the new drive.
As far as your data you could reuse your old SSD using the special case you can get with either SSD supplier or just make a full backup onto an external drive using TimeMachine then restore onto your new drive.
por
Hello Dan,
Is there an upper limit of the size of SSD I can use for MacBook Air 2017, please? Thank you, from Ming
por
These are custom drives so it is what it is! 2 TB appears to be the largest offered.
Don't forget the larger the drive the more power it needs, so going larger than 2 TB will likely effect your systems run time.
por
You can use a Samsung SSD’s with an adapter. It has worked for a handful of users.
Apple will of course tell you otherwise. And their drives are slower.
Pontuação 0
2 comentários:
You can also use your current Crucial SSD by using an adapter from Sintech. As long as your SSD fits the form factor for your MBA (M.2 2280)
por
Can you pls. post the description/link of the sintech adapter that worked for you?
por
Can I use SSD from older Macbook Air Early 2015 on my Macbook Air 2017? Is there any compatibility or performance issues?
Pontuação 0
1 dos comentários:
I am not sure, can't remember - You have to confirm that the adapter has the same pin setting with the SSD. I have the Samsung evo m2.
This is the adapter: Sintech NGFF M.2 nVME SSD Adapter Card for Upgrade MacBook Air(2013-2016 Year) and Mac PRO(Late 2013-2015 Year) - and I actually have this on a 2017 Mac book air
por
I dont think you can upgrade the SSD as they are soldered to the board. Just buy the one with the maximum amount of SSD that you can afford. 128GB is too low for any practical purposes unless all you want to do is browse the internet and other simple tasks . Regards : Typhoon TV Apk
Pontuação 0
1 dos comentários:
Of course they are not soldered in. There are enough videos showing how to replace the drive so why would you even post something like this without checking first? The MBA 2017 is just a speedbumped 2015 model with no new hardware otherwise.
por
If there may be any app that work ideal in time period of excellent and subtitles, it’s not anything cucotv apk. Yes, you could now watch all of your favorite movies and collection in your very own language. You have the choice to select the language of the subtitles at the start of the app release. ***CucoTV APK*** Otherwise, you may visit settings of the app after which go to subtitles phase to choose the language. So, you have got  one of a kind methods in which you could pick and configure the subtitles of any movie or a show.
Pontuação 0
Adicionar a sua resposta
parvindersingh1313 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 42
Últimos 30 dias: 227
Duração total: 106,897
