Ir para o conteúdo principal
O DualShock 4 CUH-ZCT2 foi anunciado em 2016 para substituir o controle CUH-ZCT1 lançado em 2013. Este controle é semelhante ao modelo anterior.
Control doesn't turn on
The control does not react, doesn't work with the cable connected to the console
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
Your cable may not be working properly, in which case, you should check to see if it has any physical damage. You may have to buy a new cable.
However, this could also be a battery issue. You may have to replace the battery. iFixit has a device guide that will instruct you on how to do so.
Another issue could be that your controller isn't charging properly. As I mentioned earlier, this could be an issue with the cable. However, it could also be an issue with the charging port. iFixit also has a device guide that will instruct you on how to replace your controller's charging port.
Esta resposta foi útil?
Pontuação 1
1 comentário:
my controller is on and virating not letting me do anything
por Compartilhar
I had a similar problem, my DS4 wasn't turning on, even though it was charging normally.
when I opened it I found that the (I think it is called) Ribbon Circuit Board ( a thin layer with many connection lines ) was broken on the like that connects the PS button, I order a new one online and replaced it and it worked perfectly.
Imagem
Pontuação 0
Adicionar a sua resposta
Jocsan SV será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Ao todo: 1,599
