How to change the battery
Esta é uma boa pergunta?
Look on the back and give us the Axxx number and/or the EMC number so we know your exact machine and we can get you to the correct battery and installation guide.
Also I would suggest downloading, installing and running Coconut Battery so you know your batteries exact status instead of using Apples idiot lights.
Esta resposta foi útil?
Thanks Mr. Mayer.
This was a bad question as I thought I had seen the process before here in the forums but later with a little more research I found the process I had seen before was in the repair guides and that walked me through the complete process. Super easy :)
Thanks again.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 66
2 comentários
Unibody or retina? Which year?
por iMedic
Thanks iMedic,
This was a bad question as I thought I had seen the process before here in the forums but didn't find it. Then a little later with a little more research I found the process I had seen before was not in the forums but in the repair guides and that walked me through the complete process. Super easy :)
Thanks again.
por Surfalia
