Ir para o conteúdo principal
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering.
296 Perguntas Visualizar todos
My iPhone 1st generation does not charge
Hi, I recently bought an iPhone 1st gen from eBay. It worked fine for a few months but now when I plug it in it says charging please wait, and after a bit it boots up. After arriving at the home screen, it says low battery and does not charge any further, and it loops in that way continuously.
Thanks.
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta Mais Útil
It looks like this may be a similar issue? My iPhone 2g is not turning on or charging
Try a hard reset "holding home and power buttons whilst plugged into a power outlet" then try cleaning contacts. If that doesn't work you may need to replace the battery.
This answer also suggests simply trying another charging cord wont turn on or charge
Esta resposta foi útil?
Pontuação 1
more than likely either needs a new battery or charge port as its an old phone
Pontuação 0
Adicionar a sua resposta
Luca será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 496
