Ir para o conteúdo principal
A versão somente wi-fi do Air iPad, da Apple, modelo número A1474. Disponível nas cores cinza espacial ou prata, conta com o processador A7 personalizado, com configuração de armazenamento de 16, 32, 64, e 128GB.
299 Perguntas Visualizar todos
Can move icons around on screen, but can't press any buttons
This is a bizarre problem to have.
Did a screen replacement, using an OEM screen. Didn't have any problems with the repair and I checked all functionality before gluing it shut; there weren't any issues. However, now - as I'm trying to use it - the top of the screen (an area about 1.5" by 4", top left corner) won't let me push any buttons. I can move icons around in the affected area, but I can't press anything (like the "back" button in the Facebook app, for example). Why would the digitizer do that?? And is there anyway to fix this??
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
If you check your work is the digitizer flex fully plugged in and the latch closed?
Esta resposta foi útil?
Pontuação 1
Sound to me like one of two things,
#1 what ULOCK JOCKS said witch is the flex cable could be causing you some issues due to either minor damage from the closing up process or just came unseated.
#2 in that corner of no response there could be a very minor hairline crack in one of the digitizer panels which could also be causing this issue for you either way screen has to come back off in-order for any further trouble shooting to happen on your part. Good luck let us know.
Pontuação 1
1 comentário:
Yes that was what I was going to say next snaps man!
por
Adicionar a sua resposta
Grace Wong será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 47
