On/off switch won't stay on.
When turning on the Mighty Dwarf to the micro SD side of the switch, it slowly slides back to the off position. How can I remedy this?
Esta é uma boa pergunta?
Better late than never I guess
Had a similar problem, that has worsened since then, in my case it's the switch itself that is the problem. Seems like the switch is of an inferior quality.
But wouldn't recommend to solder it off just yet, maybe check if there's gunk in-between the switch and the switch-arm.
The switch-arm that is visible from the outside of the device is like an adapter that is connected to the switch on the pcb, in order to limit the amount of dust to enter, and to make it look pretty..ier
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 21
Duração total: 174
