iPhone 6 dead screw brackets question
Hey ! So i was changing the chassis of my iphone 6 the other day and when i finished and plugged it in the charger without screwing the lcd shield it worked for a bit but then phone turned pretty hot and the screen went yellow..
I know i messed up 2 of the screws..the one just above the right upper corner of the lcd shield and the second of the top left side of the motherboard..
Now the phone is shorted and dead and everytime i put the charger in it turns burning hot..these two screw brackets do not short to ground but after removing the brackets no damage is visible.
Update (10/13/2017)
thanks for the answer its not the screws of the lcd shield its the upper right of the motherboard and it doesnt seem to be damaged
i know i just messed this capacitor its gonna be in place soon
Update (10/17/2017)
still burning hot when i plug in the charger dont think it was long screw damage after all
anyone has thoughts as of what might be shorting and how to fix this?
Update (10/27/2017)
after i apply the freeze spray the cpu instantly heats up and all the elements above..is it possible that the cpu is shorted ?
Esta é uma boa pergunta?
9 comentários
where does it get hot
por daniel
i guess on the pm ic or somewhere close
por dennis
from the photo there doesnt seem to be to much damage to the screw holes, you could put isopropyl or freeze spray on the board to locate the source of the heat. if the pmic is heating up it doesnt mean to say its the problem. try isopropyl and and power and it will give you an area to check for bad components
por daniel
tried freeze spray didnt notice anything just heating up instantly on these areas...c5202_rf seems fine also
por dennis
theres quite a few vcc main components around that area, just out of curiosity, was it a pre assembled lcd with camera and sensor etc already attached
por daniel
Exibir mais 4 comentários
