Why wont my greenlight come on my ds lite
when i put my charger into my ds lite the orange light comes on. i cant get the green light to come on
Esta é uma boa pergunta?
I believe the green will come on after the battery is fully charged. The Nintendo DS Lite's power light will change from green to red when the battery life is around 30%. The battery requires approximately three hours of charging. You will know when it is fully charged when the amber charging light shuts off.
Esta resposta foi útil?
Check your battery, it might just need replacing. Also make sure that the battery connectors are clean and free of corrosion. I also seem to recall that there is a fuse for the charging circuit. So if you replace your battery and you clean all the contact, and made sure that your contacts connect with tNintendo DS Lite Battery Disconnect battery contacts let us know, I will try and find more info.
Hi,
Have you dropped the ds ? check the L2 and L4 Which are on both sides of the board. If the console rattles before taking apart that could be your problem. A ds lite will do nothing if either of these components have popped off the board. Also check for moisture damage. Thx
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,475
